Those documents you sent me state the t15 runs up to 10 amps. Not sure how I would be able to lower that.
Have not pulled the board, but went out to the panel after the pump shut off and can hear a humming. When I unplugged the SWG, the humming stops. Panel correctly states there is no flow and reporting the power error.
Oddly I just tested me FC and found it a bit higher than expected, assuming the SWG was not working. Wondering if somehow the board or relay has now failed in a SWG on state. Which would obviously not be good.
I really hate how non robust it seems that pool electronics are. Might be looking at a $400 board or even just a $600 full panel. ?
