I have a pool company open and close my pool, so I don't have direct experience with that process. Recently I came back from a trip to find my system gunked up with pollen, catkins, and stuff. In the process of de-gunking, my system lost its prime. Getting things restarted was *really* hard. Is there a trick I don't know?
My pool is about 3 ft below my equipment, with a horizontal run of about 120 feet. Two skimmers plus a main drain. I tried several rounds of the following:
--Close returns, skimmers, main drain
--Open pump trap and fill with water from a hose
--Seal pump trap
--Open return line
--Turn on pump
--Quickly open one skimmer line
When I did this, the water I'd added got sucked into the pump well enough, but I didn't manage to get the system started. I did several sequential rounds (being careful to close the skimmer line before opening the pump trap) without success.
Eventually I got the system started with a real Rube Goldberg deal: I tightly jammed my vacuum hose into a skimmer port beside the pool, stuck the other end of the hose atop an extension ladder, and stuck a garden hose on full blast into that. This pushed enough water through that skimmer line that I could keep the pump running, and slowly suck the air out of the other skimmer line.
Surely there's a better way??
--Seal pump trap
--Open return line
--Turn on pump
