I believe I have a pressure side leak, and I’m hoping it’s in my pump. Yesterday morning, I happened to be outside when my pump started and I witnessed air coming out of the pop-ups. Went and checked the plumbing, didn’t see any leaks, powered off the pump. Once the pump was off, I heard the sound of my filter draining. Again, didn’t see any leaks. Rotated my intake valve from pool to spa, and the draining of the filter / pump stopped. Rotated back, and the draining continued. A closer look around the pump found a small leak coming from the pump/motor transition.
Now I replaced the impeller and associated seals this spring, however the kit I ordered did not come with a new seal plate o-ring. The existing o-ring looked like it had rolled and wasn’t in the best shape but I didn’t have a replacement. So I coated it heavily in silicon and re-used it. Any chance the above issue is due to a failed seal plate o-ring?
