Hi TFP,
I am a relatively new AGP owner, as on 2019. I have a Hayward DE finger type filter and a 1.5HP pump. I am have an issue over time with pressure. Ideal pressure on the filter is 10 P.S.I. When I first opened the pool last year and this year and added DE, 5 scoops, to the filter, the pressure is 10 P.S.I. and I see normal strong pressure from the return. Over time, the pressure value goes up and by the time it reaches 20 P.S.I. I see greatly reduced pressure from the return. I am priming the filter daily and that helps for a little time, but the starting P.S.I. generally starts higher each day and gets to 20 P.S.I sooner. I backwashed the filter after a month and added 4 scoops, and that returned P.S.I to 12, not 10 for a short time and now I am back up around 15-20 P.S.I. priming the filter daily. I am trying to figure what to do next. I am trying not to waste DE by doing another backwash. Last year, I had the same problem. Last year, the only way to get it back to 10 P.S.I. was to open the filter and completely wash it out and start over. I have shutoff values on both sides of the filter to do so. That said, I wondering if there is another solution to this problem rather than opening the filter and completely rinsing it out.
Couple side questions:
1.) Should I use 4 or 5 scoops of DE? The manual says use 5, but my installer recommended 4.
2.) Should I have to prime the pump daily? I am and that does seem to help initially But over time the pressure gauge goes up / pressure goes down from the return.
Any advice would be greatly welcomed and appreciated.
Sincerely
Jeff
Sincerely
Jeff
