- Jun 8, 2019
- 4,581
- Vinyl
- Pentair Intellichlor IC-60
Pool tech says he thinks it’s an issue with the pump. Guess I’ll call Pentair and see what they say.
Basket is fine, only fits one way. These things just slip through it because they point the direction of the water flow. We end up with a ton in our filter every year. Hard to say if the impeller was impeded but I can’t imagine it was spinning well with pine needles pressed between the diffuser and seal plate against the impeller.Was there enough debris to impede the impeller?
Is the basket installed correctly?
Also can’t hurt to make sure all the screws are tight where the wire slides in while it’s offOk, hopefully, the problem is resolved.
If it continues, I would rig up a voltage and amperage meter that can log the readings over time to see what's happening.
They were. So not sure why that error popped up.Also can’t hurt to make sure all the screws are tight where the wire slides in while it’s off
