Good morning,
Trying to better understand Parts Per Million. Is a FC of 8.6 read as 8.6ppm or am I way off base?
Thank you!
Lyman
Example:
A pool with 26,417 gallons (100,000 liters) contains 100,000,000 grams of water.
If you add 100 grams of chlorine gas, the water will contain 1 part per million of chlorine.
All readings are given in equivalent units.
Reading.....Units.
Chlorine...Chlorine gas
TA.............Calcium carbonate
Calcium....Calcium carbonate
CYA...........Cyanuric acid
Salt............Sodium chloride
Borate.......Boron.
It doesn’t matter what type of chlorine you add, it gets reported in units of chlorine gas to standardize the numbers.
For example, if you add 100 grams of 70% calcium hypochlorite, the chlorine will increase by 0.7 ppm.
That’s because the percentage of calcium hypochlorite is given in terms of chlorine gas equivalent, which makes it easier to figure out the effect.
70% calcium hypochlorite has the “equivalent” of 70% chlorine gas by weight.
Adding 100 grams of 70% calcium hypochlorite is equivalent to adding 70 grams of chlorine gas.
