I built a little shelter to keep them out of direct sun. There's a picture in post #16 on this thread (dated April 3). It's open in the back and on one side that doesn't get sun. The tanks don't necessarily have to be close to the controller, just need to make sure you order enough tubing. Kit comes with 30 feet, they charge $1/foot for any extra you need. Mine are about 25 feet away. My understanding is the tanks have a relief valve that will pop to release the gas if the pressure gets too high.
I'm still experimenting with the injection duration and flow volume to keep the pH in the range where I want it. Also there are two modes, one where it injects every day, and another where it injects every other day. Initially, I was running injection every day for about 4 hours at 2.5 CF/H (note, injection only occurs half the time during the injection cycle, so that corresponds to 5 cubic feet per day). At that rate, a 20 lb tank (175 cubic feet) would last about 35 days. I'm currently running at the same duration but every other day and cut the flow back to 2.0 CF/H to see how that goes. Will update this thread when I settle on my parameters.
