Hi all.
In an effort to get the water fully balanced, my water has gone dark and lost the clarity.
Unfortunately it happened at a time I was making a few changes namely;
Adding borax to increase PH after I had lowered TA.
Increased my CH from around 250 to 400.
Increased by CYA from less than 30 to 100 and then down to 80 or so.
I did an overnight chlorine loss and found that it dropped only 0.5ppm. I never thought it was algae as my FC has been good.
The other thing it happened around was when I turned on my solar connect to my roof, and also change the pool suction to pull from main drain as apposdd to main drain and spa.
Any thoughts here on how to resolve and my next steps? I think my swim season is over as the weather is cooling.
HomePool
Build Type: Plaster
Volume: 75000 liters
Latest Test Result Summary:
FC: 6.5 (28 minutes ago)
CC: 0.0 (9 hours ago)
pH: 7.6 (9 hours ago)
TA: 100 (9 hours ago)
CH: 425 (16 days ago)
CYA: 80 (9 hours ago)
SALT: 4640 (28 days ago)
TEMPERATURE: 21° (7 days ago)
CSI: -0.15 (28 minutes ago)
Test Results 2020-04-14 @ 06:28 AM
Free Chlorine: 6.5
CSI: -0.15
Notes 2020-04-14 @ 06:26 AM
Pool water is still murky. Completed an overnight chlorine loss test and it dropped Down to 6.5ppm.
Water was seen to be darker around the time the CYA, CH was risen. As PH was still low it was about this time I also put in 1kg of borax to increase PH
Test Results 2020-04-13 @ 09:15 PM
CYA: 80
CSI: -0.15
Test Results 2020-04-13 @ 09:10 PM
Total Alkalinity: 100
CSI: -0.17
Test Results 2020-04-13 @ 09:07 PM
Free Chlorine: 7.0
Combined Chlorine: 0.0
pH: 7.6
CSI: -0.24
HomePool
Build Type: Plaster
Free Chlorine: 6.5
CSI: -0.15
CYA: 80
CSI: -0.15
CSI: -0.17
Free Chlorine: 7.0
pH: 7.6
CSI: -0.24
