guy,
No reason to be sorry, I just felt that you were somewhat frustrated..
SWCGs are supposed to make your life easier, not harder.
Generally temperature and sunlight go hand in hand.. Several days of bright sunlight will eat a lot more chlorine than cloudy days, for sure..
I find it much easier to over-produce FC and then cut back, vs. starting low and trying to increase.
Each pool is different of course, but I would want to make sure at 800 RPM that your skimmers are still working well. In my mind you want to do two things at the same time.. Generate Chlorine and to skim the pool. My pool does both well at 1200 RPM.. I suggest that you try 1000 RPM, but that is completely up to you.
I am not sure what you mean by "setting up a skimmer" routine? Basically, when you are in the Pool mode the skimmers are working. I don't think it makes sense to run the pool at a speed to make chlorine if the skimmers are not working. Not saying that it hurts to ramp the pump speed up a couple of times a day to help skimming, but the skimmers should be working at the chlorine production speed.
Keep in mind that skimming takes patience. Skimmers are slow workers, they are not supposed to have huge volumes of water passing through them at high speed. If you are used to a single speed pump, then looking at a skimmer using a VS pump is different. My skimmers have "almost" no water movement when running at 1200 RPM, yet they work great.. I can fill up a hairnet full of junk in a day or so.
Tell me what you are trying to do with your IntelliCenter and maybe I can help or at least get you pointed in the right direction.
Jim R.
