BattleOfYakima
You're very close. I'd vac or brush as often as you can, keep FC topped off, backwash at 25% over clean PSI, and really make sure you understand the TFP way of adding DE and when to backwash. You can post how much you think you should add, how fast you should add it, when you should check the psi and then of course, don't forget to backwash, rinse, backwash, rinse, then filter - turning pump off before all switches, turning in same direction.
Correct - only concern in vinyl pool is calcium scaling index (CSI) on pool math - but you only have to check that a couple times a year.
Also - thought for the future, I wonder if you should allow the FC drop below 10 before the party so you can quickly ensure/adjust ph 7.2-7.8, then immediately bring back up to shock fc. Experts?
Vinyl pools did not have to worry about CH I thought?
