Hi all,
Been an avid TFP reader/follower since acquiring home with pool in 2020.
I thought I had this pool opening thing down pat, and it has worked till now...
But this season seems to be different.
Here's what I've done so far:
Scooped as much debris as possible (had plenty of it), got pH down from 8.4 to 7.3, raised CYA from nothing measurable using TF-100 to 35ish, raised alkalinity from 40 to 70, then started SLAM.
Within 3 days pool slowly demanded less chlorine, and went from swampy to cloudy white.
However, I can't seem to get the water from cloudy to clear.
I deep-cleaned the Hayward S244T filter for over an hour till it ran clear 10 days ago to see if that would help; no difference.
I have found in previous seasons that a cup of DE helped clear up faster; it doesn't seem to be helping much now.
I am currently trying to keep it SLAMed. My FC is at a steady 20 using FAS-DPD, CC is still Approx. 2.
But it is barely clearer than a week ago.
I should add, I am going from a starting pressure post backwash of 13.5 to 18 nearly twice a day, and backwashing out cloudy water. So it seems like filter is doing something. But if I recall correctly, I may have loaded this filter with Quikrete pool sand before I knew better...
But it did work ok for last 3 seasons...
Any ideas?
Thank you!
Any ideas?
Thank you!
