Alrite guys, sorry for the delay, I'm a police officer, and I worked the weekend and I had a VERY busy weekend....
BTW, Awesome super bowl game!!!!!
CL - 0 (obviously)
PH - 8.2 (or higher, I think, it was even darker than the 8.2)
Calcium Hardness - 250
Total Alkanity - 100
CYA - Either inconclusive or 0.... I'm assuming 0.
I didn't test salt because obviously there's none in there. Also, keep in mind, this was my very first time using the TF Pro and let me tell you, IT WAS AWESOME!!! At this point in time my fresh water has been sitting with nothing in it for going on 3 days now, I have to go out of town tomorrow, I need to get this stuff in the pool before I go, so I'm going to plug these numbers into Pool Math and see what it comes up with.
FC - recommended adding 102 oz 10% to get to a goal of 5...
I'm ASSUMING 5 is a good number?? I've read before you can get away with 3 in a salt pool, but that makes no sense to me, so I just went with 5. Instead of 102 oz, I just went ahead and did a whole gallon (128 oz).
PH - to get to 7.5, recommended 27oz of 31.45% muratic acid. Since I think my PH was well above 8.2 (it was very red) I just went with an even 30 oz.
Total Alkalinity was good @ 100 (lucky I guess)
CYA - called for 90 oz (by volume) of stabilizer. One full 4 lb bag was 75 oz (by volume) so then added another 15 more for a total of 90 oz by volume. Only thing I think I screwed up was I didn't put it in a sock, I've never done that but read you should. But that was a lot, it woulda taken a BIG Rear SOCK!!
Salt- to get to 3000, obviously I didn't test, it called for 402 pounds, so that's (10) 40 lb bags - I went ahead and put in 8 of the 10 in, so that would be 320 pounds of salt. Pretty sure my water level just went up after all of that
. This way, I can let everything mix around, and I can test my salt for the first time, and see where its at.
So what yall think?? Did I do OK for a first timer or did I totally wreck my pool??? lol
@Texas Splash
@ajw22
-Calvin
