Pool/Spa Spillway pump plumbing
azpoolspa2022
2
Phoenix AZ
I'm plumbing two 3HP Intelliflo Vsf for pool, 12" raised spa w/spillway & nine therapy jets.
Plumber advises the booster pump be dedicated to bubbler, grotto waterfall & slide with the filter pump supply for pool returns & spa returns & spa therapy jets.
My concern is the filter pump will not be able to supply adequate flow to spa jets. To avoid a third pump install, is it feasible or not to install on the booster pump a valve w/ check valve going to the spa jets to add flow to the spa jets.
