Inherited the pool, handy homeowner, not a pro. Slide 25+yrs old and itself is in good shape. YT has some good vid on the fiberglass restoration. Ladder fine, support legs all need to be replaced. Legs currently embedded in concrete/grout, likely after several resurfacing/repairs. I am not expecting to be able to re-use the existing inserts.
The easy solution would be surface mounts over the existing holes, but I will know.
Q: If I am going to do concrete work anyway, surface mounts more versatile/safe or replace the inserts for a clean look?
