I am redoing a pool at a house i just bought. best we can tell it has not been run for several years. It is a concrete/plaster pool with an attached hot tub. I am still tracking down what each line goes to but am on the fence as to weather i should cut everything out and replumb it and replace all equipment or try to make what is there work? The plumbing set up seems to be a bit of a mess and near as I can tell it must always go through the small heater for the water to return to the pool. It seems a bypass would be best for when not in use but not sure on that. I am also not certain the DE filter even will hold pressure. The system is missing the second motor which I think is either for the hottub or a booster for a pressure side cleaner? There is also a timer wired in as well as a freeze timer of some sort that you can set for certain temperatures . I would appreciate any feedback that can be offered on whether i should rehab what is here or remove it all and start over. I need to check the heater as it may be ok but I do think it may be workable.
