We are doing a renovation to our pool that was built in the 90’s that involves adding a spa, new beam, and a gunite step. We noticed that ground water is leaking into the pool through the new gunite in certain areas. The contractor says that this is not a problem and we should proceed to installing the PebbleTec.
I am concerned that the PebbleTec will not hold up correctly in those areas due to water coming in from the outside and I may have a problem after the contractor has been paid.
Any thoughts on my situation based on the posted pictures? Do I move forward with plaster or is this an issue that needs to be immediately addressed?
