My pool builder has to replace all the tile on my pool which is also causing me to have to have to pool replastered. When the pool was built they installed GloBrite lights to work with my EasyTouch controller. I am agreeable to stick with Pentair so everything will work correctly with the automation, but should I stick with the GloBrite, keep the niche and use the adapter with the MicroBrite, or switch entirely to IntelliBrite. If you think I should switch I would be very interested in your reasoning. Thanks.
