Won't do anything to the pump. The small amount added probably wouldn't harm the filter, but it sounds like a gimmick to part you from your money. If you want the water to feel better add a couple of bags of pool salt to it and let it dissolve. Cost would be about the same. It won't hurt anything, will last as long as the water stays in the pool, and most people love how it affects their skin.Would this be ok to use?? I definitely don’t want to add anything that could mess our pump up. I’m
+1Welcome Back!!!
+1 # 2.do not add that to your pool.
I didn’t see where it had algaecide in it. Wanted it for the moisturizer and scent that it add to the pool. Thought it would be nice to add if we had a party.Has a clarifier and algaecide (copper) in it. Why do you want to use it?
Thank youWelcome Back!!!
In a word, No, do not add that to your pool.
Remember this post you made after all your work last year?
How Clear is TFP Clear? Let's See (Pics Only Please).
I am so thankful for this site! I tell everybody about it. This was our first year with a pool. It has stayed clear all year! I knew absolutely nothing about pool chemistry….it’s just so darn easy! So thank you for all the help! So glad we didn’t waste a ton of money on buying the Frog Leap pacs.www.troublefreepool.com
Then here are are recommended chemicals. If it is not on the list, don't use it.
Recommended Pool Chemicals
Which should I buy? TFP's recommended pool chemicals are cheap, easy, and won't unbalance your pool water.www.troublefreepool.com
Interesting comment of adding salt to a non-salt pool to give it the feeling of a water softener! How much salt per 10,000 gallons would be the limit?Won't do anything to the pump. The small amount added probably wouldn't harm the filter, but it sounds like a gimmick to part you from your money. If you want the water to feel better add a couple of bags of pool salt to it and let it dissolve. Cost would be about the same. It won't hurt anything, will last as long as the water stays in the pool, and most people love how it affects their skin.
Members have reported getting the feel.of salt around 2000 ppm, and getting a slight taste of salt around 3000 ppm.How much salt
Moisturizing water... That is pure marketing genius right there.
