Hey guys, Hope everyone is keeping well out there. I have a pump issue I'm trying to diagnose.
We just had a lot of rain and the pool is overfull, the filter was also a couple of days overdue its backwash and the last time I had looked when it was working was running about 20psi. Yesterday I noticed that the psi was down to 0 and there was no flow. I emptied all the things, skimmers and filter basket. I stuck a screw driver in and tried to see if there was debris in the impeller which didn't help. I tried running on recirc and backwash, again no flow anywhere.
The strange thing is that the noise sounds normal enough from the pump, although I guess it does sound slightly like it is struggling just a little, but not hugely different to normal. But I am quite sensitive to its noises at this stage and I noticed the psi at 0 before the sound. My best guess is that it could be a blockage? Or maybe the pump is bust in a way that I can't tell the sound difference. It is a century Centurion pump if that helps. Image attached.
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
