Pool Permitting: Window Latches/ Door Alarms (already searched the forum)
cgtx
Active member
Jul 23, 2018
33
Austin/TX
Hello! Our pool construction is (knock on wood) nearing the end, after many delays, and we have spent days spending tens of hours online trying to find acceptably- rated window latches (door alarms, too) that we can order and receive ASAP. Our builder was vague in what he said we need: Window Latches must be ASTM F 2090 approved and state it on the equipment, and door alarms must be UL 2017 rated. We are in Austin, TX. Try as I may, I have searched high and low and can not find the answers to this on our city's website. Neighbors have said their inspections passed recently with cheap equipment that did not meet these standards, but I never seem to have that sort of luck. We have casement windows that crank outward, and supposedly we need devices (rated above) allowing 4" or less of egress. I have only found ones that are $100 each and take weeks to arrive. I need them for 10 windows, and I need the alarms for 6 doors. I did order those at $76/ pop.
Does anyone have specific models to look up, particularly for casement windows? My builder is no help aside from the ratings I mentioned above. My poor kids deserve to have their parents off of the computer, searching for expensive products we will install once and then never use again... THANK YOU!!!
HermanTX
2,755
Katy TX
This may be a possibility for the window. Probably best to call the company. It is unclear if you can just buy the device and not the whole window.
  • 19980717_All Brand WOCD Brochure-LR.PDF
revitup
665
Pawleys Island, SC
Fiberglass
Hayward Aqua Rite (T-15)
I was going to say I have several that came off the day after the inspection. You have 10 windows and 6 doors that open onto to the pool area? Holy cow!
Reactions: cgtx
cgtx
Active member
Jul 23, 2018
33
Austin/TX
To think I was posting that from the kitchen and had been forgetting to include the kitchen windows this entire time when I’ve spent tens of hours with my nose buried online, searching! It is 12 windows. 😩🙇🏼‍♀️ That’s $1200 + about $90 in tax just for latches, alone, which won’t even arrive in time, to be the approved ones. There has to be another answer. I hope windows don’t need alarms, too, like the doors do.
@HermanTX For some reason I am unable to open the link. Thank you so much for your trying to help.
HermanTX
2,755
Katy TX
It should download to your download folder.
Reactions: cgtx
jamjam
668
NY
If they are casement can’t you just remove the cranks and say they don’t open. Then put the cranks back on after you pass?
cgtx
Active member
Jul 23, 2018
33
Austin/TX
You all may be on to something... brilliant, I’d say. Food for thought... thank you so much!! :)).
... Unless they then alert some other city department and tattle that we aren’t up to code because windows don’t have egress... 🙄 Going to mull over this option. Thank you so much!!
jamjam
668
NY
do you have other windows in the room that don’t open to the pool area? As far as I know you only need egress in a bedroom.
cgtx
Active member
Jul 23, 2018
33
Austin/TX
These are just the downstairs windows which face out to the pool behind the back side gates- that’s what my builder says needs latches/ alarms. I was thinking about the egress situation as well: every one of the rooms where there are casement windows also have French doors, so I’d assume that would mitigate windows not having egress. I’ve not been able to find the code online, which is driving me crazy, and the builder hasn’t responded to that question. Will nab him in the morning. I want to see code for myself. The passing comments from the foreman, with the ratings thrown in at the last minute when I pressed for specifics, aren’t cutting it.
Would love it if everyones’ “inoperable” idea would fly! Thanks!
