Pool Perfect+ Phos Free with SWG and other SWG questions?
One last question (yeah right) on the bonding, the panel documentation shows a dotted line for bonding on the ground bus bar with the line going to both the neutral bus and the ground bus. I was going to remove the bonding wire that is connected to the bonding lug on the pump and connect a new bonding wire from the SWG to the pump bonding lug. So no bonding should be on the grounding bus like it is currently wired?
The word bond is used in different contexts.
That panel sticker is not referring to your pool bonding wire just because the word bond is used.
In the US you do not connect the bond wire to any electrical grounds. The code is different in Canada.
