Recently moved into a new house and still trying to get my bearings on the pool. Have a negative edge w/ a catch basin and an auto fill device located next to the catch basin. My issue is I’m constantly coming out to water coming out of the overflow pipe (located next to the auto fill).
What I’ve observed so far....
The level of the catch basin varies by a couple of inches when the spillway pump is off.
Some of this seems to be the wind pushing water into the basin. One night when we had a storm so much water went into the basin the overflow pipe looked like a garden hose running....
The water is coming out of the overflow pipe only when the pump is off.
I only notice the auto fill is kicking on when the pump is on and the catch basin is lowered by water going to the pool above.
Is my issue the overflow pipe being a little low, the auto fill needing to be adjusted to not put water in so quickly or a combination of the two? I get occasionally having water overflow but I'm thinking the autofill is putting too much water in when it doesn't need it. Then the pump circulates enough to keep everything looking normal but when it shuts off at night the level increases and overflows....
