So, I feel like I panic each year opening the pool because it's been 8 months since I last gave it much thought......
BLUF: new company opened pool (20 yo 35K gal gunnite) and left chlorine pucks in skimmers, which I read isn't ideal, so I made some floats and have had them in there. Water cleared up in 2 days and two weeks later I'm still waiting on a big vacuum to clear out leaves/debris, but have been trying to balance. The water was too cold to start up the SWG, but have tried to balance everything else in preparation for the vacuum (which I want to happen before adjusting water level and adding salt and turning on SWG). I've added chlorine pucks trying to keep the FC up but after a few days it just disappeared and I can't seem to get any FC to register! Water is still clear, but mess on the bottom looking greenish (but it has since opening). Is it eating up the available chlorine? Should I shock? Add liquid chlorine?
Am I correct to wait on vac until adding salt and turning on SWG?
5/7 pool open, water clear in 2 days
5/12
FC 2 (added 1 puck to 9 already in there)
PH 8.0 (added 5lb 5 oz dry acid)
TA 120
CH 200
CYA 60
5/14
FC 3.5
PH 7.4
TA 120
CH 200 (added 25 lbs hardness increase)
Salt 2000
5/17
FC 0 (added 3 pucks)
PH 7.4
CH 275
5/19
FC 0 (added 3 pucks, total 6)
5/20
FC 0, CC 0.2
PH 7.6
TA 120
CH 275
CYA 40
5/12
TA 120
CH 200
CYA 60
5/14
FC 3.5
PH 7.4
TA 120
Salt 2000
5/17
PH 7.4
CH 275
5/19
5/20
FC 0, CC 0.2
PH 7.6
TA 120
CH 275
CYA 40
