Welcome to TFP.
I hope you have downloaded
PoolMath.
Post a complete set of test results from your K-2006C and we will help you understand your water chemistry.
Read
Iron Fill Water Filter - Further Reading on how others manage with iron in their fill water.
Read
ABCs of Pool Water Chemistry
thanks, ajw22! I'm very much enjoying this community and learning tons and tons every day. Thankfully, I can report a clean pool...so far. ha!
Day 1 (test from pool store):
TA - 128
pH - 8
They tried to sell me all sorts of garbage, and I politely pushed back on some...but relented on others I think I'd use (lo-n-slow), despite having all of the TPFC recommended chemicals at home. I was under the impression they would ding me on my warranty if I didn't follow their regimen.
They recommended I shock with dichlor. I have not done that.
They recommended I dissolve and apply 4.75lbs of Lo-n-slow (which they sold me, even though I have gallons of muriatic at home), which I did to lower the TA.
The installer still has some other aspects of the pool to complete, so I'm still willing to play nice until I can get my pool fully completed (cover, spa, etc.).
They told me to hold off on putting in CYA (which they were selling at some exorbitant rate..I politely declined, since I had some at home) and wait for the maintenance crew to show up to show me how to properly apply CYA (I have my socks ready
). They'll come by soon to show me the ropes.
Anyways, I retested pH today and the FC.
FC - 1.4
pH - 7.2
CYA - 0
The FC is due to the tablets. I am thinking of blowing through all the tablets before I start using my 12.5% LC, but those Dang tablets take forever to dissolve.
I haven't put in any CYA just yet, so it's still zero. I'm expecting to dissolve and apply the CYA tomorrow and will test for its it in a couple of days. Pool Math recommends I put in
132oz of CYA! Thankfully, I have 4 socks that I'll be putting 8lbs of this stuff in.
How long can I expect it to take to dissolve all that CYA? I have two skimmers and was thinking of putting in 2 socks w/ 2 lbs each in each skimmer and running the pump on high for a few hours....squeezing each sock to ensure dissolution.
Also quick question,
can we swim while the CYA dissolves? I read that we should wait 10 minutes here after any chemical application, but I wasn't sure about CYA since it'll be releasing into the pool-water supply over several hours.
edit: They did sell me these trichlor tablets that I put in.
I just realized they were trichlor and not straight chlorine...so I'll lower the amount of CYA I put in due to the CYA content of the tablets.
