hi all
we will be adding a pool to our rear garden here in the uk for this summer {currently under going a lot of re construction work} the garden level slopes away from the rear of the property and the patio are will be approx 600mm/700mm above ground, so we are looking to add an above ground pool but sink it part into the ground so its flush with the patio, so approx 600/700mm in ground also.
some questions if i may
is there any type of above ground pool more suited to being installed partly below ground
ive seen pools with vertical steel frames and ones with angled tubular supports any real difference in terms of performance or lifespan
can i add propper walk down steps to the pool, not the clip on ladder type
can you alter liners to allow for the water to flow over an edge like an infinity pool
regarding weight we plan to go for approx 10m long x 5m wide do i need to do anything to create a base or is the earth plus solid insulation good enough for it
thanks
scaff
thanks
scaff
