Hi All,
I am new here, and this is my first post. Last month we bought a house with a small pool (about 15,000 gallons by my estimate). The pool has a Hayward SP3015X20AZ Super II Inground Pool Pump driven by a US Motors EB130 2HP Motor. I thought motor ran loud & rough, but the pool guy said it was normal (and both my neighbors motors also sounded similar). I've been mainitaining the pool myself with the advice & tips here at TFP (Thank you!), and the pool looks real nice, clean & blue.
The motor is set to run from 10AM to 6PM everyday. Last week, I was home during the day and noticed that the motor was randomly stopping abruptly and restarting after a few minutes. I thought it was over heating because it was very hot here in Dallas. It ran ok during the weekend so I didn't look into it further.
Well, on Monday it stopped working for good. I hear a humming noise from the motor but it won't turn. I did my research and here is what I have tried so far:
a) Checked the voltage at the motor with a multimeter - getting steady 220V.
b) Checked the pumps impeller for any debris - none found and it turns freely.
c) Checked the motor shaft at the back and it could be turned freely with my fingers.
d) The motor has only one capacitor (35MFD, 370VAC) and it looked ok. I pulled it anyway and tested it with a multimeter which read less than 1MFD. So I assumed the capacitor was the problem and got a replacement from Amazon with the same specs. Tested it and it reads 35.5 MFD on my multimeter. So installed it and thought the problem was solved. Nope, motor still won't start, only hums.
e) With the power on, rapped on the motor casing with a rubber mallet, tapped lightly on the motor shaft - nothing happened.
f) With the power on, gave a few quick spins to the motor shaft with a screw driver, tried both clockwise & anti-clockwise - no dice.
f) The only thing I didn't check was the centrifugal switch. So, I decided to look at that and started opening the real well cover. It had four bolts, got three off and, wouldn't you know it, the fourth one rounded off on me - I gave up after struggling with it for 10 mins and only managed to round it further.
What are my options at this point? Did I miss anything?
- I could get a bolt extractor set and remove that rounded bolt, but what would I find inside that could be an easy & cheap fix?
- The motor board or winding could be damaged, needing repair or replacement that is beyond my capabilities.
- I could spend the $$ and have a professional look at it, but I doubt they would suggest anything other than replacing the motor or the entire pump.
- I was thinking about getting an energy effcient dual speed or variable speed motor, so maybe use this breakdown as an opportunity to upgrade the motor?
The pool is still blue but has started showing some signs of stagnation. How do I maintain it while the pump is down?
With the long weekend coming up, time is not on my side. I would like to get it fixed atleast by next weekend.
All suggestions/advice welcome.
Thank you.
Thank you.
