Pool Math
kpromero
Platinum Supporter
147
Louisiana
Jandy Truclear / Ei
Sorry for possible dumb question but I am usi g the Pool Math app and for some reason cannot change my targets. Not sure what I am doing wrong. CYA says I should be at 70 - 80 and I am trying to set target to 70 but it keeps saying my target is 40 when I am adding my log information
Check how your pool is setup. For a high CYA like you wish, the app would need to see you have a SWCG. Do you?
All settings actually do this. Here are a screen shot
FC is set to 3 but I want to change to 5
107236
I change to 5 but when I get out of this and click FC again its back to 3
That is correct. The recommended level will always revert to the level the app has programmed. We discussed having that user defined but are hesitant because users could start using an inappropriate level. So if you want your target different than the app recommends, then you need to change it everytime.
