Humm. Well, not sure if this is a computer cookie or cache retention issue, maybe one of the Admin folks will confirm. But I was in Poolmath last night/this morning as well. Depending upon how long ago I was in the calculator, or which computer I am using at the time, I may have to re-enter my NOW and TARGET goals, as well as my pool volume size. Not so sure it is able to save your parameters for such a ling time.
ok, so I just deleted all values to "0" and rebooted. I then input the current info and target. Still showing "not set up". Apparently it is a computer issue that I need to correct right?
My experience with PoolMath is that it will default back to most settings you input. Not specifically to "save" them but just as a default. Gallons is the only one I really need because of the way I use it and the last value entered in gallons seems to be there next time.
Those always have stored what I entered, for all three values. But if it is like you go to the page for the first time, all the items will say Not Set Up.
