Saturn94
- Mar 11, 2015
- 1,761
- Vinyl
- Hayward Aqua Rite (T-15)
What are the 4 login options? I suspect since I don't use social media I'm going to be left out.
Hi there, I'm going to try and explain our decision on the cloud syncing a bit, and how it works. I definitely can appreciate the concern for data security and control, so I'm happy to be transparent about how this works and what we're using.
First of all, the data is stored locally. You can use the app in airplane mode, the data is always kept on the device, in a local database. If you never connected your device to the internet, your data would always still be there on that device. One of the next features which I've already started working on is the ability to Export and Import your data, as I believe it's important that you ultimately control your data. We aren't trying to own your data, just make it convenient.
We use a technology called Realm (for those interested, Realm: Create reactive mobile apps in a fraction of the time ) to implement the cloud syncing and syncing between devices. Each user login is associated with its own Realm (or database) locally, which gets synchronized to the cloud (hosted in Microsoft Azure), so it's not one big database, it's actually many small databases.
Early on, actually before we settled on using Realm, we decided that the lowest friction way to implement cloud sync would be to automatically provide it for everyone. This minimizes the chance of data conflicts if a user installs the app on multiple devices, and it also reduces the number of first time run paths when we add in some sort of payment/subscription for the app. I think it's fair to say we would consider adding the ability to opt-out of cloud sync in the future. It's certainly possible, it's just not what most users are going to want or expect, and we feel it's not the best use of development effort at this point in time.
I appreciate that you realize you're probably in the minority here, and unfortunately I think that's true. I don't want to sound dismissive of your request, so we'll definitely log this as a feature request for future versions of the app (we have an internal bug/feature tracking board). I'm all for giving users the choice, but like I said, in this case specifically, it's not as high priority as other things such as adding import/export and graphs/charts.
Thanks for your feedback!
Yes! Pick me! I'd love to test!
How many users have only one device? Likely less than you'd think. We want the user to log their data on their iPad at the table then use their phone to calculate how much bleach to add by the pool. We want you to use a huge screen to view your data. All this is really only possible by saving the data outside of your device.
I'll log this and see how difficult it will be to setup.Loving this app, thank you.
One improvement or addition that may help is a 'pool tittle' on the logs page for those with multiple pools. The small screen on the iPhone hides the 'pools' list that is always visible on the larger screen. The overview page does include a 'pool title'.
By any chance did you change your CYA level? If so, it's set to automatically update your target to a new level.And I have noticed that within the overview page my set target is not being stored, it defaults back to the app set targets.
Thanks. Thought I needed to use email link, but was able to d/l TestFlight and install TFP app. I then promptly used the wrong social login account and am trying to reinstall with proper a/c.Have you installed TestFlight on the iPad? If not, try that. The App should be able to be downloaded on your iPad via TestFlight. This will change once we submit the App for full approval and get into the Apple App Store. For now we're doing it this way simply because we're still testing things out.
Uninstalled and reinstalled app. Still showing incorrect FC range for SWG. Is incorrectly showing the 3.0 to 4.0 liquid chlorine range for plaster.
