One key item that differs is that we the industry typically suggests using chlorine “pucks” which are very acidic while we suggest liquid chlorine or a salt water generator, both which tend to see an increase of pH. The industry tends to suggest a higher TA level as this prevents crashing a users pH level when using pucks while our lower level TA tends to greatly slow the rate of pH increase thus using less acid to maintain your pool.
