- May 3, 2014
- 62,902
- Fiberglass
- Pentair Intellichlor IC-40
It's 14 years old.Is my best and easiest to just get another Jandy PLC1400?
Ok I might need help to know which is the trip sensor. Is that the grey cable from the flow sensor to the board?If you disconnect the trisensor, does the 171 code go away?
Ok will try these steps. Just started looking into it. Let me see what it says.Disconnect the flow salinity temp sensor from the front board.
Press and hold the test buttons marked salinity and R-temp.
While still pressing the test buttons press the ‘Salinity’ key (‘C’) on the front cover of the unit.
The LCD should read 2.8 gpl*.
While still holding the two front board test buttons press the ‘Pool Temperature’ key (‘D’).
It should read 75° F or 24° C.
Next, press and hold the board ‘H-Temp’ test button, and at the same time press the ‘Salinity’
key (‘C’) together with the ‘Chlorine Production Rate’ arrow down key (‘A’) on the front cover of the unit.
The LCD should read 91° F or 33° C .
Yes that's what I am thinking. I do have a pool home warranty. Going to give it a shot if it will cover the SwG. Any one had a luck to see if they cover?It's 14 years old.
I would just get a new PLC1400.
Jandy AquaPure 1400 Replacement Cell, 40,000 Gal Pool, 16ft Cord, Tri-Sensor - Model PLC1400 - INYOPools.com
Replacement Salt Cell for the Jandy Purelink Chlorinatorwww.inyopools.com
Yes.Ok I might need help to know which is the trip sensor. Is that the grey cable from the flow sensor to the board?
