Pool lights not turning on
Mike,
How do you want them to work. As group or individually. If individually, you will need two more transformers.
I suggest that you work on the lights after you know if everything else works or not.
Reactions: Poolbreh
I would remove all wires on relays and start fresh, remove vdc transformer. It looks like it was just an attempt at nothing. FP and heater and outdoor light and ET are directly to cb. The bottom cb look like spares.
Also confirm voltage at heater before firing. It comes from the factory preset with the 230v socket. FP heater ET T are good being directly to breaker. Outdoor, pool lights, and blower should be on relays. Every circuit needs to be clean and labeled and circuits run together. It looks like FP and heater run through same conduit.
