I have an issue with the lights on my swimming pool through the COMPOOL Lx3830 control panel. When I try to turn on the lights at the panel, the relay clicks, but the light on the panel does not come on and neither do the lights in the pool. The circuit breaker is closed and I have voltage to the panel. I created a video showing the issue below. This is the third relay I used to make sure it's not a relay issue. When I hooked up the lights bypassing the system, they worked fine. There seems to be an issue somewhere between the relay and the junction box to the lights. When I initially installed the system I was using 500-watt lights. I have replaced them with 19-watt LED lights. The lights did not work with the 500-watt lights either. Any idea what's happening? Here's a video explaining what I see. Thank you.
