So our pool light hasn't worked for about three 1/2 years and I finally decided to get around to testing the voltages first at the junction protruding from the ground next to the pump. No voltage on the white and red wires going to the light. So I open the original PX300 transformer and the breaker box next to it. Two breakers: one dual for the pump and one single breaker for the (light?). Nothing tripped. So I test voltage going into side where the breakers click onto the metal rail. I'm getting 120v from the house to the rail (duh, because the pump works). So I check voltage coming out of the single breaker...120 volts. Ok. checking the two black wires that should show 12v from the transformer? Nada. So I replace the transformer with a new PX300. Flip the light breaker...nothing. Alrighty.
The thing is, the wire from the single breaker disappears back into the conduit that supplies power from the house and disappears up into the home. But there is also a black wire coming from that same conduit. The white wire goes to the metal rail on the breaker side and is twisted to the white wire going to the transformer. The black wire from the house is twisted to a black wire leading to the transformer. So now I'm stumped. It is almost like it bypasses any circuit breaker and just feeds power directly to the transformer. Could this mean there is a breaker in the main panel of the house that this black and white wire are fed power to??? Because the only breaker labeled anything pool is "Pool Pump".
