Howdy, I know there are many previous similar threads. Mine: had 25yr old plaster pool chipped out and remade with micropebble in February. I asked to include "make the light work" and he allocated $100 charge to me for it. I watched the guy test it (while dry) and it worked (though he rapidly turned it off because of "heat"). I don't think they actually replaced anything.
6 months later tried it at night for the first time - light trips off after ~one sec. Pool contractor came to look and verified but the conversation has (so far) ended this way: "What do you want me to do? 1. replace the bulb and gasket? 2. replace the GFCI for $75 3. Take $100 off a fix (charge me $700). I presume the fix includes a cable replacement. First, is this a reasonable position for him? (I'm leaning yes). Second, what's my best choice of 1-3? I hardly ever use the light but I'm thinking resale.
One other piece of info that may be useful. 10+years ago had a similar tripping problem which an electrician tracked down to a cable short to the spa light on the same circuit. He took it out (we don't use the spa), and the pool light worked.
