Hi,
I will try to give you a quick overview. My pool builder is no help and I will not go into details, just let's say he won't even respond.
Ok, so since the pool was finished in November 2018, I have thought the pool may be leaking. I have a 12 x 20 inground pool that has AquaBright for the interior. Anyway, the pool builder said it is not leaking and stopped returning my calls. He said it was evaporation. I loose about 3 inches a week. However, since a few weeks after we had the pool completed, our house ran into some structural issues so the pool has been covered this entire time. (So since it is covered 24/7, we could not do the bucket test) It has a solar cover and a blue tarp over it. It seems weird to me that there can be that much evaporation through multiple covers. I am in Florida as that might matter. Anyway, the travertine around the pool was damaged during the structural fix. So we pulled it up to replace it. When we did that, we noticed on the one side of the pool (we have not pulled the travertine up from all sides yet), a large cavity. It seems to be running a large length of the pool on the 20 foot side. I found it when I pulled the travertine and fell through. I attached a picture that may not be the greatest. It is about 2 to 4 inches below the ground level and extends as far as I can reach along the edge of the pool (at least 2 feet deep, maybe more in some areas, maybe less ( I just tried ramming a piece of rebar through the ground. Guess what? It went the full 4 feet down in many areas., so there is a major void there and I enclosed some pictures and everywhere there is a hole, there is hollow ground underneath). At first before I saw how deep it was, I thought maybe it was just erosion from water seeping between the travertine pavers. But I am thinking this is way too much to be erosion and if it was, it would be directly under the travertine. Not 4 to 6 inches below ground level which is about where the pool water line should be. I have no idea where all that sand is washing. I am hoping for some ideas, suggestions and the like before I even try to approach the dealer as it is not a good relationship at all and I don't want to accuse him of something that is not his "fault". This is my first pool, so I am sorry if this is a stupid question.
Another piece of information. When they were building the pool. They were going to upgrade my interior shell coating (after the concrete but before the AquaBright) with a product that was supposed to be waterproof and I think it was called BaseCrete. Long story short, they said they would not experiment on my job as the manufacturer would be there and show them how to apply it. The manufacturer never showed and they failed at applying it. They tried again. Failed again. They then just did normal plaster or whatever is normal before the topcoat of AquaBright. I don't know if this is related.
There is no plumbing on that side of the pool. There are no drains or skimmers or anything on that side. So I think somehow it is leaking. I don't know if AquaBright is watertight or not. But I guess the pool tile is not. So maybe it is leaking from there if they did not apply everything right (by the way, they screwed up my tile the first time too and that had to be redone).
