Ok! Going to take my time and explain this the best I can! (Mods: Not sure which sub-forum... so I'm putting here...)
Inground pool. Flunked the bucket test badly. Losing almost an inch overnight (pump off) and getting worse. Loses when pump on at same rate.
Dove the pool with gear. Rit Dye and syringe. Pump remained off for several hours before dive.
Dye is not drawn anywhere near light (with light installed and with light removed (inside light well).
Dye is not drawn anywhere around tile line (and will drain below tile line).
Dye is not drawn around skimmer (more on this later) - and the part that makes me wonder why isn't the dye drawn here (more below)
Dye is not drawn around outlet
Dye is not drawn around bottom drain.
Inside the skimmer, there are two holes, one is suction (goes to pump) (which is what we plug the pool vac into). The other hole leads to the bottom drain. They are not connected via the fitting that I have seen some use.
With all equipment off, if I place dye in the suction side of those two holes, the dye settles on the bottom and stays there.
...if I place dye in the hole that leads to the bottom drain it does *not* settle and is gone quickly. (5 seconds or less).
Now... I have never, not once, had a use for that non-suction side hole, and I have never, not once, had use for the bottom drain.
Question:
Does it sound like the leak is between the non-suction side hole in skimmer and the bottom drain? Seeing how I have no use for either, I have purchased two winter pool plugs to close those two openings and reevaluate. These are what I am going to try:
and/or
The main objective, for now, is to just stop the leak - our plan is to redo the patio, and we can solve these issues permanently.
Let me have it!
Pete
Question:
and/or
Let me have it!
Pete
