Pool in spa mode but spa/pool heating up together
kdrumz
10
Florida
Hello
New pool/spa owner.
Pentair system.
I’m in spa mode and heater is on but my pool/spa seem to be heating up together. Goal is to get them heating up independently to set them at different temps.
Plumbing setup:
When I switch to spa mode, the actuator/valve handle turns towards ”spa”, which from my research is correct to heat them independently.
Hoping someone can point me in the right direction.
Thanks!
Jimrahbe
27,606
Bedford, TX
K,
If the handle moves and points to the "Spa" label, then the Pool return should be completely shut off.. If this is the case, then no water should be going to your pool.. All the water should be coming out of your spa drains and being sent back to just the spa.
Is your spillover still working in the spa mode?
What makes you think the pool water is getting hotter?
Better pics of your equipment would help.. Don't add them to an outside site, just post them here.
kdrumz
10
Florida
K,
kdrumz
10
Florida
Sorry was on mobile earlier. Ignore above posts. Here are more pictures of my setup, currently in spa mode.
When I went from pool mode to spa mode, the actuator turned the valve from the middle to the handle pointing towards "SPA", which I think is correct.
However, the other actuator didn't move when I put it into spa mode and the valve is pointing off towards "SPA Main Drain" like in the picture below, which I'm not sure if that's the issue.
img_3368-jpg.379056
mknauss
51,247
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
In Spa Mode, switch the toggle on the Suction side actuated valve to the other ON position. The handle should rotate and be pointed at the pool suction.
Jimrahbe
27,606
Bedford, TX
K,
Both valves should move when switching between the pool mode and spa mode..
In the Spa mode, the Intake valve (the one in front of the pump) should allow water to come in from the Spa drain and close off the input from the pool (skimmer /main drain)
Does the Intake valve move at all.. either when going into the Pool mode or into the Spa mode???
kdrumz
10
Florida
K,
So the only valve moving is the one in the first picture labeled with “return” and “spa”. When I put it into spa mode, the valve moved from off facing in the middle to off facing towards “return”. The other valve didn't move with off facing towards "spa main drain". Should I manually move that one so handle faces towards "spa main drain"
kdrumz
10
Florida
Not familiar with the set up yet with and where the suction side is. So with the other actuator valve which currently has "off" facing towards "spa main drain", I need to manually override that so the handle is instead facing "spa main drain"?
mknauss
51,247
Laughlin, NV
Fiberglass
The valve is not moving when you switch the toggle?
If there is no movement, the actuator is not connected to your automation system.
Jimrahbe
27,606
Bedford, TX
K,
I assume you have an EasyTouch.. Is that true?
If the Intake valve never moves...
Then it could be that the Actuator is bad
It could be the the valve itself is stuck
It could the the EasyTouch is bad
It could be that the actuator cable is not plugged into the correct connection inside the EasyTouch.
Show us a pic of the valve connections on the main board.. Just remove the two screws on the top where the LCD is and the whole top will fold down..
