Does anyone know if there is a pvc fitting you can install that you can connect a pool hose? I need to add a drain line downstream of my pump and was going to install a diverter valve and wanted to put a fitting to connect a pool hose. This would allow me to remove the hose when I am not needing to pump to drain.
