Well you guys helped me cut my pvc pipe last time to open my filter up to change the sand but I’m back again with another problem that I neglected earlier until I realized it was slowly draining my water level in the pool.
One thing to note.
1) when I bought the house the heater didn’t work. I’m not looking to fix the heater just stop the leak so water doesn’t drain from my pool.
My question is when I turn on my filter my pool heater is leaking significantly from the bottom.
What are my options?
When I turn on my filter the heater kicks on with cold air as well. How can I completely shut off the heater as well as stopping the leak?
TFP can you guys help me again! My pool looks amazing right now because of you guys. Hoping this is easy fix.
One thing to note.
