- Jun 1, 2021
- 5
- Vinyl
- Zodiac LM3-24
Hi everyone,
Thanks to all for contributing to this tremendous resource.
I am a relatively new pool owner. This is the third season I am using my pool. The pool was built in 2014 along with all its equipment, including a Raypak 400,000 BTU gas heater. It is a salt water pool with a SWG. I have kept the chemistry and balance decently for at least the time I have owned it (2 years).
The first summer the heater was fine. In the middle of last summer, the heater would not ignite and would give a pilot not sensed error. I figured it was just the pilot assembly. I had a gas contractor look at it and upon opening it, the insides were all corroded, rusted and destroyed, essentially falling apart. See photo.
During COVID, pool heaters are in demand, prices are 30-40% higher and they don’t even know if this heater will come in weeks-months even if I order it now. It would cost me about 5K (Canadian) to replace this heater... to be honest I’m in no rush and am going to try a solar blanket this season as we use the pool when it’s hot out anyway.
my question is... has anybody seen this degree of damage for a pretty expensive heater after only 5-6 years of use? The gas contractor says there may have been a leak inside. There’s apparently a newer model (copper nickel) that is recommended for salt water pools specifically. They also said the heating supplier said I have to run my pool pump 24/7 to prevent this from happening again, saying for salt water pools this is necessary. I have never heard of this... obviously this is less than ideal.
can anyone help/comment on this situation?
many thanks in advance!
