- May 2, 2017
- 104
- Plaster
- Hayward Aqua Rite (T-9)
I have been trying to figure out the best setup to reduce electrical usage from our pool. In the past year, our bill has steadily increased and currently is over $200 and this time last year was about $120. There are a lot of variables (new pool heat pump, rate increases, working from home, etc) so trying to see what can be done to bring it back down a tad. I have tried a few different setups with the pool heat pump, but so far haven't come up with anything conclusive. So over the next 2 weeks, I am doing 3 different scenarios. The heat pump will be set at 84 for all. The first scenario will be to run pump 24H at 1200 RPM. Second scenario will be to run pump 12H at 1200 and 12H at 900. Third and final scenario will be 6H at 1200 and 18H at 900. I have been running my pump 24H for a few months for more consistent chlorine generation from my SWG. At 900, the heat pump will not kick on. So the idea is to see if it's better to let it heat the pool around the clock vs only during the day and trying to find what window of time is best. The biggest problem is the weather. Being FL, this time of year it can be a high of 70 or nearly 90. Rain can also be a significant factor, but hopefully through the two weeks it stays consistent.
As I was thinking about this, I ran across a couple different devices that claim to be able to monitor usage. One is called Sense . Just curious if anyone has any experience with it or a comparable product.
