Pool Filter upgrade/replacement
markfwelsch
11
Baytown, TX
I want to replace my current pool filter and want to know if there is an upgrade to what I have now.
My pool is about 25,0000 gallons and the current setup works fine, but it seems like it restricts what comes out my waterfalls sometimes.
Currently I have Jandy Model CV460.is there any recommendations that yall have?
Thx!
Note for other TFPers, this topic was somewhat covered, but not resolved in this thread:
What does "sometimes" mean? What configuration or conditions are present when you find the restriction?
What pump do you have (make/model)?
Post pictures of your equipment pad so we can see everything. I saw your picture from the last post, has the pad changed.
How are you testing your water? Post a full set of results.
When was the last time you cleaned your filter?
Is this this same problem as your last thread?
Have you removed the cartridges to see if the problem goes away?
