- Jul 21, 2013
- 66,373
- Plaster
- Pentair Intellichlor IC-60
The TFP article is generic covering a wide range of products.
Follow the manufacturer recommendations when it is available.
I don’t have PebbleTech, I have a pebble radiance finish which is from a different company and is listed in my signature. Seeing how chlorine was already added it’s not exactly an option to just wait anymore. My plan is to hold 3-4ppm fc until Friday at this point and then add the cya on the 3rd day and bring it up to 40-50. I understand you guys are all volunteers and I very much appreciate the knowledge and time everyone puts into this site. I am just trying to learn and not screw it up in the processIf you want to wait, then wait.
PTI is the manufacturer of your PebbleTech finish. The others you are reading are not.
If you still have reservations about that chlorine you added,...... don't With no CYA in the water, it will be gone in a few hours. No worries. Follow your builder's recommendations and we'll be here to get you going when you're ready. Easy stuff.My plan is to hold 3-4ppm fc
Unfortunately I could not find the start up info on the website. It seems like it might be a proprietary blend from my pool builder potentially from universal but I’m not positive of that. The person they sent out to do start up wasn’t overly helpful and said the water was good to swim even though it had zero sanitation. Does my plan of keeping it 3-4ppm until tomorrow the (3rd day) then adding cya sound like an ok way of handling things at this point.What company is the Pebble Radiance from?
Do they have startup information on their website?
You know more about your situation then we do. Things keep on getting revealed to us.Does my plan of keeping it 3-4ppm until tomorrow the (3rd day) then adding cya sound like an ok way of handling things at this point.
Filled is different then filling. The thread title started withI guess that is where I am confused. It says after 72 hours to start adding chlorine and cya? Is that 72 hours after fill or the pebble was done? Mine only just finished filling this morning.
The title of the thread was “Pool filling” until last night a picture of a low filled pool was also included in the initial post. It was then changed to “pool filled” as it progressed which seems to normally be suggested here. Also as is suggested my signature states pebble radiance as a finish. The information I’ve provided is accurateFilled is different then filling. The thread title started with
“Pool filled, …”
Pebble is the brand name for PebbleTech versus an unknown pebble finish.
Our advice is only as accurate as the information we get.
You nailed it.If I’m not mistaken all I need to do now is make a few margaritas and open the umbrellas right??
Pool is crystal clear as seen in the pic!
How many pounds of salt is being added?Good Morning,
The pool company is introducing salt today. Just wondering what the recommendations are if any for things to be aware of?
Started with 350lbs and will add more in a few days if needed. I was able to find most answers to my question via search. I’ll leave the pool on high for 24 hours which will leave the cell off. Tomorrow I will test salt levels bump up to my target fc levels with liquid chlorine and then let the swg take over at 50% and see where I’m at tomorrow night fc wise. Over the weekend I will go get a bit more stabilizer and bump my cya 15-20 ppm to the middle of recommended levels. Please advise if I should be aware of anything else. Thank youHow many pounds of salt is being added?
