Measure your flow rate at your bibs , see how long it takes to fill a 5 gallon pail , then you can figure how many gallons per minute , then figure gallons per hour . Divide your pools capacity by your gallons per hour calculation and that should give you a rough estimate .
If you can run 2 hoses (from separate bibs) you might get it done a little faster, but not twice as fast - maybe 25% faster, depending on your plumbing and water pressure.
Does not matter 1 bib or 100, you can only get X amount of gallons per hour out of your main water line. 4 hoses will just cause them to have lower pressure, you will have no pressure in your house.
