- May 3, 2014
- 62,811
- Fiberglass
- Pentair Intellichlor IC-40
Updated my signature. I don't see the ports being labeled on this brand new MPV however.The valve ports are typically labeled. Change your signature, it is confusing.
This is fine. Just ensure the word "inlet" on the 3 way valve is facing the pump inlet. The photo appears to be correct.Is it ok to put the 3 way valve sideways like this? Two inlet pipes are too close together, unless i use the original layout with multiple 90degrees
This is really looking good. Well done. That little sight glass on the waste line is to look at the water during backwash to see if it is clear or cloudy.View attachment 478480
Thank you so much along the way
