Selenap
Well shoot. Are you using an overlap liner or hook/unibead? If overlap, you might need to loosen it more than you have. If using the hook, you don’t cut anything off the coping. If using the unibead, of course you have to cut to fit in the bead track. I assume you know that. So it could possibly mean the liner is not cut correctly or not stretching properly if it’s the fitted version. I’d call the people you bought it from. Tell them your problem. It’s pulling in at both ends so it seems you need a different liner. You have done your due diligence at this point I believe. I’m sorry this happened. You could jerry rig the posts by jacking them up but you’ll be out of level and it’sa new pool. You shouldn’t have too.
