There was a power outage and when the power was restored the pool began draining out of the skimmers. I turned off the main drain and it stopped. However, I need to understand if this is an issue. Is there a fix?
Without us knowing more about your pool, there's no way to tell.
Is it above ground or below?
Is the pump below the pool?
Do you have an automation system?
What type of filter, and is the waste line open or hard plumbed to the sewer?
