Pool deck questions
I hope I posted in the right forum (mods feel free to move if not).
We bought the house in 2014. The pool/spa and deck were built in the early 2000s.
We've been dealing with an extremely frustrating problem. Water/moisture is getting under the floors of the house in the rooms adjacent to the deck. Our wood floors in these areas have moisture damage. We've replaced the damaged areas twice and now we will tear out the floors and put in tile.
But onto resolving the source of the moisture...
There are 5 drains throughout the deck which are all functioning.
However, from the right side (left in picture) to the middle of the house, the concrete is poured at a level that is at the top of the foundation. I believe this is allowing any water that misses the drains to seep into the brick and weep holes. The deck then slopes to the left the house (right in picture) and towards the front of the garage. I guess the idea was to get water to flow towards the driveway.
We installed new 6" roof gutters which help quite a bit but it has not resolved the problem.
I can think of three ways to fix this:
1. Tear out 10" of deck along the back of house and put in gravel (no drain).
2. Tear out 10" of deck along the back of the house and put in a channel drain.
3. Tear out a larger portion of the deck (see drawing #2) and put in grass.
#1 would be the least expensive but would it even work? Would #2 hold in a heavy storm or hurricane? #3 seems like a surefire solution but I'm having a hard time figuring out how to make it look good.
Any thoughts, suggestion, or ideas will be appreciated. Thank you.
If water is actually getting in where you think it is, channeling it away is the best solution. Putting in gravel seems like it’ll just hold more water at that 10” channel unless it’s slopes to allow it to drain out to a lower spot. If you were going to fill with gravel, adding a french drain pipe on the same spot wouldn’t be much more expensive. I’m also not sure grass does a lot for you unless you change the slope of the grass area to slope away from the house.
Reactions: travelfeedsthesoul
This is Houston, it's possible things have moved around and the house is now lower in relation to the deck from where it was originally constructed. It may be worth calling out a foundation company to put a water level on your slab and see if your house shows to be down on the pool side. Not that it would make the resolution any better, because if that's the case you'd need to break up the deck anyway to have the slab piered.
Reactions: borjis
It seems odd that the pool is so high, which makes me think that maybe the pool floated.
I would put in at least one dry well so that you can monitor the ground water and pump it out as needed.
If water is actually getting in where you think it is, channeling it away is the best solution. Putting in gravel seems like it’ll just hold more water at that 10” channel unless it’s slopes to allow it to drain out to a lower spot. If you were going to fill with gravel, adding a french drain pipe on the same spot wouldn’t be much more expensive. I’m also not sure grass doesn’t a lot for you unless you change the slope of the grass area to slope away from the house.
We haven't seen any signs of foundation damage, like cracks inside the house, windows or doors not shutting, or cracks on the exterior of house. I've walked around the house and there I see no damage to the foundation.
Interesting. We have heavy clay soil and a shallow water table. Do you think a dry well will work here?
Check with a local contractor who has experience in ground water control.
It partly depends on what the pool backfill is.
If they used rock, then it is likely to be worthwhile putting a sump tube close to the pool in the rock.
It looks like you could probably put in a tube near the pool wall or just outside the deck on the left.
How shallow is the water table?
Where does the overflow drain go to?
In the area at the back of the garage which has poor drainage, I can hit water within a foot of digging. In other areas with acceptable drainage, perhaps two feet.
That's a lot of water.
I suspect that the pool probably floated at some point.
I would think that you would need to create areas of rock that allow for water to drain to a central sump tube so that the water can be pumped out.
Here are some places I found on the Google.
The house seems low.
Is the house on a slab or crawlspace?
I think that the excessive water in the ground is coming up and soaking the floors.
You probably need to get some serious water management to prevent further damage.
Check with the below company to see what they recommend.
For any company, verify business license, any necessary professional licenses, bond, insurance, worker's compensation etc.
Check their reviews.
Check with any organizations they claim to be a member of to see if they are in good standing.
If you've been there 7 years and seen no movement, that's a pretty good sign.
You can see the house is on a slab, and that the deck is even with the top at the left half of the house. Only three ways that happens: 1. Pool moved up with the deck, evenly, with no failure in the hardscape (highly unlikely), 2. The house moved down (in Houston, likely, but generally not evenly). Or 3, it was just built wrong in the first place. If he hasn't seen movement, I'm going for #3.
IMHO your first idea of a recessed channel drain between the slab and the deck is probably your best bet. Grass wouldn't absorb water fast enough with any of these 2 inch an hour rains we get, much less a TS or hurricane. My first goal would be to get some vertical distance so water isn't just flowing into the weep holes and ponding against the bottom plate.
Reactions: Mdragger88 and A.O.
