- Mar 22, 2024
- 40
- Vinyl
- Pentair Intellichlor IC-40
Hi All,
Our landscape company is installing the coping. we have a 16ft x 24 ft pool with a pool cover that is sunken flush and will be covered by coping too.
Our stone coping comes as 4ft long pieces. How would this normally be laid?
I would assume you run 4 pieces along the width and then 6 along the length, however the landscapers have cut three pieces shorter on the lenght at about 3 ft 9 towards where the pool cover would be which looks strange. If the automatic cover changes how you install at one end would you still not use 4ft pieces till the end and then cut one piece to size to make the last one fit rather than chaning the length two thirds into the pool?
How is this usually installed?
Also if you have a rockface coping, how much should overhang the pool?
